Posted July 6, 200915 yr comment_288876 I'm trying to help a friend out with her Z, and I just can't seem to locate the thread I'm looking for. I seem to remember probably 5 or 6 years ago a thread on one of the forums about using a bushing found in the Help! parts that you find at any auto parts store to rebuild the door hinge pivots. Maybe I"m remembering incorrectly... does anyone else recall this or have any info that might help?Starting to think that a Chrysler door hinge bushing fits the Z shifter and that's what I'm remembering... :stupid:I did find this thread but it doesn't directly address my question. http://www.classiczcars.com/forums/showthread.php?t=24503&highlight=door+hinge+pin Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/ Share on other sites More sharing options...
July 6, 200915 yr comment_288878 I don't know if this is the thread, but look at the thread "Door hinges" post #14 started by a7dz. It will give the the following address. http://www.atlanticz.ca/zclub/techtips/body/doorhinge/index.htm Edited July 6, 200915 yr by AZ-240z Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/#findComment-288878 Share on other sites More sharing options...
July 6, 200915 yr comment_288880 Let me try that address again. Somewhat computer challenged.http://www.atlanticz.ca/zclub/techtips/body/doorhinge/index.htmNever mind. I guess this is what you had previously found. Sorry for the duplication.Dan Edited July 6, 200915 yr by AZ-240z Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/#findComment-288880 Share on other sites More sharing options...
July 6, 200915 yr Author comment_288881 I think I was confused...http://forums.hybridz.org/showthread.php?t=122484&highlight=brass+shifter+bushing Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/#findComment-288881 Share on other sites More sharing options...
July 7, 200915 yr comment_288884 I believe there is some truth to that. I cannot find it in my notes right now but I believe the Nissan Pickup bushings are correct size. The pin will need to have modifications made to it.Here is a link that I found with a google search. Read down through it for some part numbers. In the thread it talks about GM door hinge kit. My memory says Nissan Pickup but it has been many years. Its basically the same thing though.Hope it helps.http://www.nwde.org/extras/forum/forum_posts.asp?TID=3605&PN=1RobertOk I find my notes just after posting this thread. My notes match what "HainZ" list further down the thread I provided a link to. I used the NAPA kit that was for a Nissan PU. Edited July 7, 200915 yr by Robert260z To add additional notes about my notes Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/#findComment-288884 Share on other sites More sharing options...
July 7, 200915 yr Author comment_288910 Awesome! Thanks for that! Link to comment https://www.classiczcars.com/forums/topic/32447-door-hinge-fix/#findComment-288910 Share on other sites More sharing options...
