Best location for A/C Serice Ports?
Oiluj
I’m working on installation of my AC lines, bending the hard tubing.
My question is where to locate the service ports. Is there any “best” location for the service ports?
I’m assuming that anywhere that’s convenient for servicing is OK, but wanted to verify before bending and cutting more lines. I'm planning to locate my drier on the passenger side strut tower, but am open to a better solution.
Thanks!
I don't think there's any set place where they should be. Obviously, they should be easily accessible for servicing. As and MVAC tech, it's always been my pet peeve to find they they're behind a panel that has to be removed as on a Lincoln LS, or mounted on the compressor is such a way that you have to get under the car, remove the splash pan, etc. (also on a Lincoln LS). Whenever I do a custom system or mod a system, I put the service ports and components where they are easily accessible.
Stephen,
Do you use the solder on self piercing taps, the bolt on design, or have you got a source for better?
Will
Stephen,
What is your opinion of the self-piercing bolt-on taps?
I was thinking they would be a good alternative. Was even thinking they could be soldered as well, but would be eaiser to mount on the hard line.
