Posted July 7, 200915 yr comment_288962 2+2 and turbo Flywheels are the same correct? If so would i be able to mount up the clutch off of a turbo onto my 2+2 and it will work right? Link to comment https://www.classiczcars.com/forums/topic/32457-clutch-question/ Share on other sites More sharing options...
July 8, 200915 yr comment_289006 Welcome to the site.According to the info at www.datsunzgarage.com/engine that appears to be the case, however I cannot verify this with any certainty. Link to comment https://www.classiczcars.com/forums/topic/32457-clutch-question/#findComment-289006 Share on other sites More sharing options...
July 19, 200915 yr comment_289941 Yes the 2+2 and the turbo both use a 240 mm clutch plate versus the 225 MM plate used on the n/a machines. Flywheel is the same just have more contact area due to the larger plate. Link to comment https://www.classiczcars.com/forums/topic/32457-clutch-question/#findComment-289941 Share on other sites More sharing options...
