I got an electronic ignition and coil from Summit Racing. From what I understand they are basically Mallory bits re-branded for Summit. So, it should install exactly the same as a Mallory Hyfire 6.
After sitting on the parts for a bit, I decided to take it to an expert since I have very little confidence when it comes to wiring. The guy that I took it to came very highly recommended, but he deals mostly with the carbureted Zs. He said he has spark, but is having trouble getting the fuel injection to fire. I had a tach adapter with it, which is also installed.
Does anyone have any experience with wiring an aftermarket ignition with a fuel injected Z? Any help would be greatly appreciated.
