Recently Browsing 0
After pulling out my transmission and taking the case off I figured out why it kept popping out of 2nd, 4th and reverse.
The problem is that the shifter would hit the back of the "socket" and not allow it to fully engage and pop out of gear. You can see where the mark is on the shifter where it hits and the distance the gear is from fully engaging over the synchro, (a long ways off).
I took apart another transmission as a test and used two shifters and it did it to both of them so I would think this could happen to a lot of them and hopefully fix them without taking them out of the car and to a tranny shop for nothing.
I thought I would be able to adjust the shift "tang" that actually moves the actuaters to change gears but it is keyed....so I just ended up grinding the shifter where it hit, enough to make sure if fully engaged and now I can down shift and back my car up without it popping out!
Hope this helps someone down the road.
https://www.classiczcars.com/forums/topic/32521-popping-out-of-gear-fixed/Share on other sites
