Posted July 14, 200915 yr comment_289543 Hey I've got a 72' 240z. I bought i about a month ago,and i'm currently fixing the engine. It has been siting in a garage for the past two years, and was running before it was put into the garage. Just from sitting, the engine has seized up. Are there easy ways to fix it or should i just take off the head and do some more major work. Any help would be great.-chris Link to comment https://www.classiczcars.com/forums/topic/32524-240z-seized-engine/ Share on other sites More sharing options...
July 14, 200915 yr comment_289548 If you do some searches here you will find many answers to this question. However, the most popular response is to pull the spark plugs and pour (I use an oil squirt gun) some atf (automatic transmission fluid) into the cylinders and let it sit for a couple days, then try to turn the engine over by hand - use a breaker bar with socket on the crank pulley bolt. You may also want to pull the valve cover and pour atf over the camshaft and the valves at the sametime you put it in the cylinders. Good Luck. Link to comment https://www.classiczcars.com/forums/topic/32524-240z-seized-engine/#findComment-289548 Share on other sites More sharing options...
July 14, 200915 yr comment_289551 Yup. Try this thread. Covers this type of thing in detail.http://www.classiczcars.com/forums/showthread.php?t=22619 Link to comment https://www.classiczcars.com/forums/topic/32524-240z-seized-engine/#findComment-289551 Share on other sites More sharing options...
July 14, 200915 yr comment_289563 If it's really a mess, there are usually all kinds of L24's available reasonably cheap as people are swapping them out for L28's and other, more eccentric, options. Check the classifieds (or post a parts wanted) here, on www.zcar.com and on www.hybridz.org (home of the swaps...).Good luck with the car. Link to comment https://www.classiczcars.com/forums/topic/32524-240z-seized-engine/#findComment-289563 Share on other sites More sharing options...
