Posted July 16, 200915 yr comment_289673 I have an original 72' 240z radio. I'm pretty sure it works. If it does work, how much is it worth. I need to make money to fix up the engine of my car and get it running so some cash would help. thx-Chris Link to comment https://www.classiczcars.com/forums/topic/32538-240z-radio/ Share on other sites More sharing options...
July 16, 200915 yr comment_289674 Depending on condition I have seen them sell between $59 and $450 on ebay.Will Link to comment https://www.classiczcars.com/forums/topic/32538-240z-radio/#findComment-289674 Share on other sites More sharing options...
July 16, 200915 yr comment_289675 I suggest you test it and report your finding along with some good pictures of the faceplate. As with most other things, if they are broken they are worth a fraction of the value of a good one. You'll likely then get some reasonably accurate estimates. Link to comment https://www.classiczcars.com/forums/topic/32538-240z-radio/#findComment-289675 Share on other sites More sharing options...
July 16, 200915 yr Author comment_289680 Yeah so the radio works and the face plate is a little dusty but can be cleaned (there are some pics). I also have two clocks from a 240z. are they worth anything in the condition you see them in the pics, and I also have two door sill plates. They are warped a little, but they are very flexible and can be fixed. They are also dusty and one has some dried on paint. Any idea on the prices. Link to comment https://www.classiczcars.com/forums/topic/32538-240z-radio/#findComment-289680 Share on other sites More sharing options...
July 16, 200915 yr comment_289687 Im after a radio for my 72z Link to comment https://www.classiczcars.com/forums/topic/32538-240z-radio/#findComment-289687 Share on other sites More sharing options...
