Posted July 19, 200915 yr comment_289930 what am i doing wrong here? the tranny is supported, i've got the hoist on the block (head and manifolds are already removed), and they come apart about half an inch, but then the flywheel tries to come out too. i can see the crankshaft there in the gap. do i have to put it in neutral? everything is definitely unbolted.we have tried pulling the block forward, aggressively, but it won't move past about 3/4" Edited July 19, 200915 yr by saridout Link to comment https://www.classiczcars.com/forums/topic/32571-block-and-tranny-wont-come-apart/ Share on other sites More sharing options...
July 19, 200915 yr comment_289938 Reconnect the slave cylinder and push the clutch pedal in to give your self an INTERNAL push and seperation, using the clutch fork and throw out bearing as a wedge. I had the Same problem once, it would NOT seperate, until I pushed the clutch pedal in and it popped (seperated) apart easily.Good luck,Dave Edited July 19, 200915 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/32571-block-and-tranny-wont-come-apart/#findComment-289938 Share on other sites More sharing options...
July 19, 200915 yr Author comment_289940 shoot, i forgot to mention it's an automatic. Link to comment https://www.classiczcars.com/forums/topic/32571-block-and-tranny-wont-come-apart/#findComment-289940 Share on other sites More sharing options...
July 19, 200915 yr comment_289944 saridout said: everything is definitely unbolted.Does "everything" include removing the Torque Converter bolts?Or do you mean that you have the bolts out of the bell housing?FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/32571-block-and-tranny-wont-come-apart/#findComment-289944 Share on other sites More sharing options...
