I've searched for the answer to this question and will continue to search but in case someone wants to help... here's the question.
I have the civic fan installed. Now it's time to connect the wires. The civic wiring has a plug with two wires, blue with a black stripe and blue with a white stripe. Which one should I splice to the red 240Z fan motor wire and which one should I splice into the black 240Z fan motor wire? Looking at the civic fan plug, there are two + indicators at the plug which is confusing. The connectors are flat and at a right angle to one another.
I would think that the civic blue/black would connect to the black or negative 240Z wire and the civic blue/white would connect to the red or positive 240Z wire.
Just want to make sure. Any help would be appreciated.
https://www.classiczcars.com/forums/topic/32572-fan-motor-swap-civic-to-240z/
