Posted July 19, 200915 yr comment_289933 Anybody try a "Battery Brain"? Thoughts? Comments? - Thanks http://www.batterybrain.com/batterybrain.pl http://www.batterybrain.com/New_BB+_Tri-fold_20070807.pdf Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/ Share on other sites More sharing options...
July 19, 200915 yr comment_289955 Probably works as advertised, but seems like a gimmick to me. No need for the electronics, just install a battery kill switch. A battery kill switch It does the same thing. And since you would have to open the hood with a kill switch, you will "see" if there is any connector corrosion. Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/#findComment-289955 Share on other sites More sharing options...
July 19, 200915 yr comment_289959 Might be handy if you are the forgetful type and leave your lights or whatever on.Steve Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/#findComment-289959 Share on other sites More sharing options...
July 20, 200915 yr comment_289987 The S30 is a simple car.... Why add struf that could get zapped...Not just a z - zdisease Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/#findComment-289987 Share on other sites More sharing options...
July 21, 200915 yr Author comment_290065 I appreciate the response. Yeah, it does sound a little gimmicky. I was thinking that it is almost inevitable that the lights get left on. Of course I could install a buzzer/chime for that and for fewer $$$. I was also thinking that the remote for the battery cutoff might delay a thief for a few extra minutes which might be enough to catch said thief and attempt to persuade him, by any means necessary not to go around stealing other peoples hard earned belongings... Anything within reason to thwart someone stealing my beloved Z. Kill switch goes in next. Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/#findComment-290065 Share on other sites More sharing options...
July 21, 200915 yr comment_290091 The logical approach is to consider how often you drive your Z. I have two DD's and the Z. Keeping the battery charged up prolongs the life of the battery. Repeated full discharge or even lower charge greatly reduces battery life. I run only Optimas (they don't rot out the battery tray area) and you know how much they cost! Even sealed wet-cells are not cheap anymore. I use a 'Battery Minder' for this purpose. This 'Battery Brain' can be very useful in an offroad/camping situation where there is no 'help' and you've fallen asleep while the radio played all night. Lights left on or a door not quite closed will kill a battery. Most of us have experienced this frustration. What's it worth to you? As far as kill switches, alarms, etc, they are all easily bypassed in older vehicles like ours. I choose to pull the rotor or a couple of spark plug wires if I really want to reasonably disable my Z. Don't want them even bothering to look? Then buy a wheel boot and throw it on the DS front tire. Auto thieves get the message quick enough. Link to comment https://www.classiczcars.com/forums/topic/32573-battery-brain-tried-it/#findComment-290091 Share on other sites More sharing options...
