Remove the outer hardware, then remove the wing nut that holds the bottom bracket to a stud down inside the rear quarter panel. Then carefully maneuver the antenna unit off the lower stud, down and then out. You may also have to loosen the bolt that holds said bottom bracket to the bottom of the antenna assembly.
