Hi I am looking for a eight or ten point roll cage for my 1971 240Z
I would like the kind that has the front (A piller) bars the go down the windshild posts to the floor, and it must be a weld in cage.:stupid:
https://www.classiczcars.com/forums/topic/3262-wanted-full-cage/
There are a couple of "kit" cages sold. They are by Autopower and by Kirk Racing Products.
The Autopower cage has the bars running down the windshield pillar and turns down to the floor behind the dash. It is a 6 point cage.
You might want to give Kirk a call to see what they have available, as they do have some more custom cage kits available than does Autopower. Of course adding a few bars after the initial installation isn't too difficult if you want to add on a couple more attachment points.
Only other thing is to have someone do a custom cage which will cost you in the 1500+ range, but will be done to your exact specs where the "kits" will not.
Hmsports here on the site builds his own cages so you might give him a try and see if he could help you out with any other questions/info on a custom built cage.
I can tell you how you can get by it if you want... :9
I am an IT guy...
If you want, I can tell you how to make it look like you went to your own website, and all you did was look at encrypted stuff there...
:P the man..
d
