Posted July 25, 200915 yr comment_290397 I am looking for some advice. While driving our 76' 280z we got into a small accident. The front ran into the back of a small car. Here is what we found to be damaged.-The front of the hood was bent down-The hood arms were twisted-Bent upper grille was bent-The right hood arm pushed into the frame that sit behind it-Smashed left turn signal-Front bumper was pushed up-Metal headlamp cover pushed back-Driver side fender buckled about an inchThere may be some damage but we couldn't find it or did not know to look for it. This is where we were hoping you could come in and lend us a hand. Is there anything else we should check? Also, looking for your advice on whether to buy the parts individually or invest in a parts car. Any advice would be greatly appreciated.-James Link to comment https://www.classiczcars.com/forums/topic/32635-280z-caught-in-a-fender-bender/ Share on other sites More sharing options...
July 26, 200915 yr comment_290403 I have two grills in great shape. I may have both signals, I have to check. Pretty sure the rest of it I don't have though... PM me an we can work out a price. Link to comment https://www.classiczcars.com/forums/topic/32635-280z-caught-in-a-fender-bender/#findComment-290403 Share on other sites More sharing options...
July 26, 200915 yr comment_290410 What about your Insurance Co. ? Do you have Hagerty by chance . Because if you do just have the car taken to the body of your choice and have the job done. If not , most likely you will need to replace the fender and hood as well as the headlight assembly and grill. I believe hoods are still available at Nissan. I have a set of sugar scoops from a early 240 I will give you , if you pay for shipping. They are the fiberglass type. Not show quality but use able. Do check the Radiator support to see if it is bent. Most likely the Bumper can be straightened and re chromed.I just read that the front fenders are NLA so look for a used one. Hoods are a bitc# to fix so look for a used one. What part of the world are you? this may make a huge difference. Nissan may still have 280 hoods.Gary Link to comment https://www.classiczcars.com/forums/topic/32635-280z-caught-in-a-fender-bender/#findComment-290410 Share on other sites More sharing options...
July 26, 200915 yr comment_290423 They had the early hoods but, not the 280's a year ago. Link to comment https://www.classiczcars.com/forums/topic/32635-280z-caught-in-a-fender-bender/#findComment-290423 Share on other sites More sharing options...
July 26, 200915 yr comment_290428 Isn't the 280 hood the same as the 240 until 77? I bought a 240 hood three years ago for under $200 new from the dealership. Link to comment https://www.classiczcars.com/forums/topic/32635-280z-caught-in-a-fender-bender/#findComment-290428 Share on other sites More sharing options...
