4spd vs 5spd
mike260z
79' ZX 5-speed has been nothing but Awesome in my 240Z. Great low end and 5th gear gets me Great MPG on the freeway. I basically do 2950 RPM's at 80MPH, which leaves a lot of pedal around 100MPH
I'm sure a few other will give the specifics on what is needed for the conversion. (cross-member, driveline, etc.)
Dave
When I installed my 5-speed, it was a straight bolt-up. Used my original 240 driveshaft, all mounts, etc. and it worked fine (except for the fact that the 5-speed tranny needed a rebuild :angry:). Wish I did that before I installed (then removed) it. I did use the shifter from the 5-speed instead of my original 4-speed shifter.
I also think there are subtle difference in the TO bearings, but I'm not sure on that.
Yes the 5 speed will mate to the motor from a 260 auto but you will need to add the entire clutch system to the car, use a flywheel from a manual and the starter might need to be changed too (not sure on the last one). The drive line might be the wrong length and the trans tunnel might have to be modified too (for the shifter to fit). I am not sure of all the mods I listed but they are just some things that come to mind when I picture the change over in my head. It is not nearly as straight forward as a 4-5 speed change. There are articles people have written about the swap on Hybridz.org and possible here too. It can be done though.
