Posted August 1, 200915 yr comment_290917 I got a new fuel pump for my 77 280z , ran good for a while,then died. It was the pump full of rust, from the tank.Now the pump is dead, can someone tell me what fuel pump I should buy and were I can get it.Also what I should do so this won't happen again. Thank you Link to comment https://www.classiczcars.com/forums/topic/32702-dirty-tank/ Share on other sites More sharing options...
August 2, 200915 yr comment_290937 You have rust in your tank. Search for " tank cleaning"; It should guide you in the right direction. When you replace the tank , Add a "g3" fram filter from pump to tank so it can catch any fine sediments in the future.http://www.atlanticz.ca/zclub/techtips/fuel/g3filter/index.htm Link to comment https://www.classiczcars.com/forums/topic/32702-dirty-tank/#findComment-290937 Share on other sites More sharing options...
August 2, 200915 yr comment_290951 Agreed, ...snip...sorry, was thinking the 280's fuel pump was in line, and not in the tank. Had to edit Edited August 2, 200915 yr by 70 Cam Guy My bad Link to comment https://www.classiczcars.com/forums/topic/32702-dirty-tank/#findComment-290951 Share on other sites More sharing options...
