Posted August 10, 200915 yr comment_291557 Having problems with the taillights on my '72 240. blinker on 1 side ,breaklight on the other side, T/L on both sides, good signal with test light on both sides all functions until bulbs are put back in, grounds appear to be OK. any ideas? Link to comment https://www.classiczcars.com/forums/topic/32784-taillight-problems/ Share on other sites More sharing options...
August 10, 200915 yr comment_291568 Lance said: Having problems with the taillights on my '72 240. blinker on 1 side ,breaklight on the other side, T/L on both sides, good signal with test light on both sides all functions until bulbs are put back in, grounds appear to be OK. any ideas?Normally problem is at the contact points inside the socketsIf not try bypassing soldered wires covered with black rubber tube.Even though they look fine, there might not bb no current flow.Very common problems.Esprist Link to comment https://www.classiczcars.com/forums/topic/32784-taillight-problems/#findComment-291568 Share on other sites More sharing options...
