smog question
T's 280z
Generally the answer is "No" on the visual unless it has a EO order number for the header.
Recently I went through this with my 76 Fairlady Z. It had a header with a fitting modified to go to the EGR. The smog shop did not accept it.
After putting on a stock exhaust setup I found a conversion diagram showing what was done on mine to be legal. Now I do not know how much of a fight it would have been with the shop over that diagram. To late now because it has a stock exhaust manifold.
My Z was run through a Federalization and emissions process to get it registered in the U.S. and California.
