Posted August 13, 200915 yr comment_291758 I'm just wondering what brand of shock absorbers are the most favoured by the members.I'm considering fitting new shockies to "Precious" as she's still fitted with resurected originals and I'd like to know if there are any that will fit straight in.Searching didn't help me very much.Rick. Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/ Share on other sites More sharing options...
August 13, 200915 yr comment_291790 If Precious has mostly stock suspension, KYB GR-2 should be about as close to stock as you'll find. Although, since they are gas-charged, they may raise the car's ride height a bit - I'd expect about 10-15mm. But since the only non-gas units I've found these days are Konis (which are reputed to be harsher ride, even when set full soft), the KYBs are probably the best choice.I am running them in my '71, with cut-down repro Euro Stage 1 springs. The ride is firm, but not harsh. Much like stock, I suspect. Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291790 Share on other sites More sharing options...
August 13, 200915 yr comment_291798 There are several options;OEM (hydraulic filled):Normal ResistanceFirm ResistanceAftermarket (gas filled):TokicoKoniKYBSachsMonroeMost people buy Tokico or KYB and move on. If you are interested in low cost, then Sachs or Monroe is a good alternative. If you want OEM, then you can be my situation and wait 3-4 months for a boat to arrive from Japan with OEM parts.Keith Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291798 Share on other sites More sharing options...
August 13, 200915 yr comment_291806 There is a good shock thread at Hybrid Z aimed more at the racey end of the spectrum:http://forums.hybridz.org/showthread.php?t=138601If I were doing up a nice street machine with reasonably stiff springs, but not a full on racer, I'd go with the Bilsteins or maybe the Tokico HTS. For a stockish ride I think Arne has it right with the GR2's. Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291806 Share on other sites More sharing options...
August 14, 200915 yr comment_291842 Oy Rick, I installed KYBs and Eibach springs. I did the struts first the springs a year later, and was favorably impressed with the KYBs. Replaced Konis which were harsh.Cheers mate, Mike Edited August 14, 200915 yr by Pop's Z Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291842 Share on other sites More sharing options...
August 14, 200915 yr comment_291845 I used Tokico blues in both cars - but they will give you a nose bleed with the regular springs. (height) Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291845 Share on other sites More sharing options...
August 14, 200915 yr Author comment_291866 Thanks for the advice fellas, looks like KYB's are the way to go.Much appreciated.Rick. Link to comment https://www.classiczcars.com/forums/topic/32818-shock-absorbers/#findComment-291866 Share on other sites More sharing options...
