Posted August 16, 200915 yr comment_292026 I am installing new wheel bearings in my front hubs on a 72 z. My question is what direction does the inner seal face? There is a grove on the seal and i dont know if it faces the engine compartment or towards the wheel. Any help would be appreciated. Link to comment https://www.classiczcars.com/forums/topic/32839-front-hub-grease-seal/ Share on other sites More sharing options...
August 16, 200915 yr comment_292070 Hi There Nutz,Normaly a lip seal has a spring on one side of the lip,this spring faces what you are sealing.If there isn't a spring then the cavity in the seal fits towards the bearing.Pack the cavity with grease before installing.Roger Link to comment https://www.classiczcars.com/forums/topic/32839-front-hub-grease-seal/#findComment-292070 Share on other sites More sharing options...
