Email logins are now active ×
Part ID Please
texasz
I have three parts that all look the same, one has a label that can be read clearly and it has this information on it:
17011 N4765
A40-000 008
8214 L28
The 8214 is 'stamped' on the label and presumably the serial number, I can only guess that the L28 indicates the part is for the L28 engine. I have Googled the other numbers and come up with nothing. Has hose inlet/outlet so I'm thinking a pump of some kind.
I have another part to add here, it's a section of wiring with a part number 27155 E4400 which I was also unable to locate via Google.
Edited by texasz
Texasz,
I can't help with the first part number, but 27155-E4400 is a fan switch cable (see fiche scan) for cars up to July 1973. The fiche I have applies to right hand drive cars, so I am not sure if the same part number applies to left hand drive vehicles.
Try this page. Hopefully it will be of some help to you in deciphering part numbers:
http://www.ratdat.com/?page_id=24
WOW, that's a great resource that I've never seen before!! Certainly going to bookmark that one. Thank you!!
Texasz,
Thank you for the info and the support document, that's perfect.
  • Who's Online   2 Members, 0 Anonymous, 591 Guests (See full list)
