Posted August 17, 200915 yr comment_292208 My Z overheated on the way home last night, and spewed out most of it's coolant. I took it into our shop and put it up on the lift today to figure out what happened. Looks like my heater core line is shot. It's fine when cold (because the thermostat isn't open) but as soon as it warms up coolant starts pouring out. I had a small leak (little dripping) there a few months ago, but tightening the clamps cleared that up. I was hoping to do the same this time (you can see I added a new clamp today) but it didn't work. I have the replacement hoses from MSA and am willing to pull everything but I'd like your guys' advice. Have any of you replaced these hoses while everything is still in the car? What's the best way to do things? Edited August 17, 200915 yr by JonnyRock Link to comment https://www.classiczcars.com/forums/topic/32859-coolant-leak-from-heater-lines/ Share on other sites More sharing options...
August 17, 200915 yr Author comment_292210 Looking at my earlier threads, someone already gave me a tip on this. But if you have anymore, do tell. Link to comment https://www.classiczcars.com/forums/topic/32859-coolant-leak-from-heater-lines/#findComment-292210 Share on other sites More sharing options...
August 17, 200915 yr comment_292211 I've done it in place, not too difficult, just messy. Remove all of the carpet and padding from the passenger floorpan before starting. You WILL make a mess in there.As a side note, I'd strongly recommend replacing any of the old cloth-covered hoses still on the car while you're at it. Mine were so brittle that one actually crumbled when I went to remove it. And that can't be good... Link to comment https://www.classiczcars.com/forums/topic/32859-coolant-leak-from-heater-lines/#findComment-292211 Share on other sites More sharing options...
August 17, 200915 yr Author comment_292217 Thanks Arne, I'll be sure to do that. I believe that these are the last of the braided hoses in mine, except for the cam cover to air cleaner line. Link to comment https://www.classiczcars.com/forums/topic/32859-coolant-leak-from-heater-lines/#findComment-292217 Share on other sites More sharing options...
