Cant get the hazard flashers to work !!!
mikemerkury
Almost done with my 73 resto. Everything electrical is now in working condition. Can get the hazard flashers to work. All connections triple checked and cleaned. Dash hazard switch also cleaned and does look in good working condition.
Any suggestions ?
Any such thing as generic hazard relay (the one by passenger side) ?
I don't believe there is a hazard relay. Test the switch contacts directly with a continuity checker.
When in Off position,
Pin 4 connected to 5, and 6 to 7. All others not connected to each other.
When in ON position
Pins 1,2,3 connected to each other, and pins 8 and 9 connected to each other.
Hazard switch diverts power from the Stop Light Circuit when ON to power the Hazard Flasher.
If the stop lights and the turn signals work properly when the Hazard Switch is turned OFF, then it's the Hazard Flasher that needs looking into.
Don't forget that the Z has TWO Flashers, one for the T/S and one for the Hazards.
2¢
e
