Posted August 20, 200915 yr comment_292407 so its seem the trans in my car is not stock seeing the trans neutral switch has different plugs on it! So how Do you ID which year your trans is car?is there cast number or stamped numbers in it some where?also whats the point of the neutral switch? Link to comment https://www.classiczcars.com/forums/topic/32894-tran-id-help/ Share on other sites More sharing options...
August 20, 200915 yr comment_292421 so its seem the trans in my car is not stock seeing the trans neutral switch has different plugs on it! So how Do you ID which year your trans is car?is there cast number or stamped numbers in it some where?also whats the point of the neutral switch?Do you have picture of the trans? (RH side would be better)If you have neutral switch (green head) with 2 yellow wire, it is 5 speed trans made 80s'. Esprist Link to comment https://www.classiczcars.com/forums/topic/32894-tran-id-help/#findComment-292421 Share on other sites More sharing options...
August 20, 200915 yr Author comment_292439 well its a 4 speed i can get photos later Link to comment https://www.classiczcars.com/forums/topic/32894-tran-id-help/#findComment-292439 Share on other sites More sharing options...
August 20, 200915 yr Author comment_292442 Link to comment https://www.classiczcars.com/forums/topic/32894-tran-id-help/#findComment-292442 Share on other sites More sharing options...
August 25, 200915 yr Author comment_292872 I got numbers off the top of the trans which read s 7322176 Link to comment https://www.classiczcars.com/forums/topic/32894-tran-id-help/#findComment-292872 Share on other sites More sharing options...
