Hey guys,
I recently rebuilt my engine and while doing so i replaced the timing chain. As I was setting timing between the cam and the crank, I noticed I was a little off. I have a 240z with a pointer on the block and 5 marks on the pulley. I read in a thread that the farthest mark to the left is TDC. (please confirm) However my new chain from MSA is just shy of reaching this postion. With my crank at the far left mark, i am just to the right of the mark on the timing mark on cam tower 1. Is this a problem?
I am so worried about this damn timing :paranoid:
Any advice would be appreciated
Frankie
https://www.classiczcars.com/forums/topic/32908-cam-crank-timing-off/
http://www.classiczcars.com/forums/showthread.php?t=34777&highlight=refresh&page=3
Check about 3/4th of the way down this page and you will see the cam timing marks and the crank timing marks along with the link marks (They are both offset by one link in the pics). Mine is a 240 also. The chain should have two marks (0's in the pics), 42 links apart. They should correspond with the cam and crank marks as shown in the pics. I believe in this configuration that the spline on the crank is facing up at 12 o'clock.
I apologize, with both sprockets timing marks on the bright links, and with my crank pulley on and lined up with TDC. My cam is a little to the RIGHT of the timing mark on timing tower 1. Just by a hair.
Would it make since to put my cam one link back? or to the left? To compensate.
Ok, I have been working on getting my engine running, I think I am back to a timing issue. I have my engine turning over have i can't get it to fire. I have gas to the carburetors. And confirmed the proper wiring order order for the spark plugs. Finally i have turned that dizzy every which way and can 't get a fire. Any ideas what direction to go. Could this have to do with the timing situation earlier in this thread?
Have you confirmed that you are getting spark from the distributor? Pull one of the plugs and turn engine over and look for spark)
