My 280zx, 1980, now have a another dangerus electrical problem. Im completly lost!.
The problem starts when I start fast from a crossing, take a quick turn or at a take over that requires a sudden rise in the RPM. The fuel and door lamp goes on and then the engine starts to cut of.
I can barly keep it running on a few pistons and when I stop I hear the fuel relay click and then it quits!.
When I turn the key it will start immediatly. Usually it will then run ok but after a few miles the same happen now without a rise in the RPM. Other times it will run perfectly for a week or more.
The ecu test lamp shows an error on the battery when I start the engine again but it disapairs shortly after.
There is also a light smell of unburnt gas
It maybe isnt connected but somethimes my tachometer shut down. But newer at the same time as the above occurs.
The alternator is brand new....
I have checked every single connection in the engine compartment that I can find and I belive also below the dash.
I have promised my friend that he can borrow her for his wedding Friday so Im afraid I prosmissed too much.
If any of you have tried something simlar or maybe have a idea please let me know - thanks!!
Hi
https://www.classiczcars.com/forums/topic/32950-dangerus-electrical-problem/Share on other sites
