Email logins are now active ×
rims 240z
jessespencer79
So I'm looking to get some rims for my 72 240z, and have two options right now. The first is a set of stock rims from a 74 260z, aluminum 4 slot, slight curb rash, and the second is a set of 14 x 7 basket weave (possibly appliance wheels) from a 72 240z, no curb rash. Don't know anything about cars, just want to get ones that fit for the right price, and look good. Thoughts? J.
Jesse-
I gotta thing for slot wheels......can ya tell? You know what my choice is but the confusion is where you say "stock - 4 slot".....Arne is the site pro when it comes to tires and wheels. What ever you do, what ever descision you make, make sure to check your wheel offset......if you don't, you could get the tire rubbing on your outter fender wells which is not cool...........be sure to check that clearence to avoid tire rash with your fenders!!
Good luck and get those pictures posted.
Jesse:
This is what the original steel wheel and wheel cover lookd like.*
Note: *On original, the chrome scollope you see would of been painted grey, the blue center should be a red reflector. Very early Z's had a "D" center. ($)
Bonzi Lon
So the guy with the 'stock' rims were off a 73 240z, my mistake! He hasn't got me photos yet.
Here's the link for the 14 x 7's on ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320415142050&viewitem=&sspagename=rvi%3A1%3A1v_&category=43954
My current wheel is 14 x 5, would the extra two inches lessen fuel economy? And what sort of price would be decent for these....
The ebay ones are 14x7 Appliance Wire Mags. I have the narrower 6" version on my 240Z. The 14x7 had a 3/8" negative offset, very similar to the 14x7 Konigs of today. Will fit OK, but watch for clearance issues up front if the car has the stock front valance. If you have an airdam, you'll probably be OK. The wider size is more sensitive to balance and vibration too.
That set is also overpriced, in my opinion. Possibly a bit high even at the opening bid, but with an even higher reserve and $650 BIN? Too much. If you like them, I can possibly set you up with a set of the 14x6 for considerably less, given a bit of time.
There was a factory alloy for the 260Z. Don't know if you got them in the US though.
In the USA, the 260Z was one year only ('74) and alloys were not offered from the factory. I believe that you could order them from the parts department, but they were so expensive compared to aftermarket rims that almost no one did. They were quite rare here in the states prior to being a factory option on the '77-78 280Z.
  • Who's Online   1 Member, 0 Anonymous, 343 Guests (See full list)
