Email logins are now active ×
Help ID these parts please!
Mytralalas260
1974 260z
<a href="http://s110.photobucket.com/albums/n103/garnoff/?action=view&current=HPIM2437.jpg" target="_blank"><img src="http://i110.photobucket.com/albums/n103/garnoff/HPIM2437.jpg" border="0" alt="Photobucket"></a>
^little red button that says push... i presses it? i sees nothing.
<a href="http://s110.photobucket.com/albums/n103/garnoff/?action=view&current=HPIM2438.jpg" target="_blank"><img src="http://i110.photobucket.com/albums/n103/garnoff/HPIM2438.jpg" border="0" alt="Photobucket"></a>
^relay near radiator on drivers side, sounds like a salt and pepper shaker... obviously shot? dont know what its for.
<a href="http://s110.photobucket.com/albums/n103/garnoff/?action=view&current=HPIM2440.jpg" target="_blank"><img src="http://i110.photobucket.com/albums/n103/garnoff/HPIM2440.jpg" border="0" alt="Photobucket"></a>
^little plug wire coming off the alternator.. what for? not plugged into anything
The first one is a maintenance starter button. You can use it to start the engine from under the hood. My 260Z had this as well, but it never worked.
That button isn't related to the infamous "mandatory seat belt" system that was required in 74 is it?
(or at least PART of 74...)
Yup. That's the emergency bypass for the seat belt interlock system. If the seat sensors failed and you couldn't start the car, pressing that button would bypass the interlock for a short time - maybe only one crank, I can't recall for sure.
That 3rd photo is what's left of the condenser, for sure. You need a new one. They're cheap and easy to find.
The second photo looks like some kind of aftermarket relay. It also looks like there are some loose wires above it. Does the car have (or had) fog lights? Driving lights? Air horns?
  • 3 weeks later...
Ttiger, the relay isnt aftermarket unfortunately, the colored wires are actually what is attatched to the relay :(
I have a question about the condenser... Could it possibly be what is interfering with my tach? the tach jumps to 8k, then bounces around occaisionally. sometimes it does jump to the right rpm and works for a minute or two... then back to 8. >< it bounces with my signal lights, with my headlights, defrost and well pretty much all my electronics.
HELP ME OH GURU's
I cant seem to find the problem with it, and honestly i'd like to know what rpm i'm at :P
Kevin
  • Who's Online   1 Member, 0 Anonymous, 496 Guests (See full list)
