Email logins are now active ×
Complete Restoration
LadyPhoenix
Ok, so in order for this Z to be mine, I have to completely restore it. It was taken apart 15 years ago and he doesn't remember much about it. I do have a book for it but it's not very informative where I need it to be so I'll be asking a good deal of questions.
Question #1: Does the '75 280Z need transmission mounts? I found brackets and I want to make sure that is what they are before I go trying to hunt down tranny mounts for a Z.
Question #2: All the bolts were lost, are these cars metric or standard?
Thanks for anyone with a helpful response.
I'm in Arvada, Colorado.
Ok, so all metric...
Question #3: Anyone know how many bolts the tranny needs to be bolted in and what size?
Question #4: Anyone know how many bolts the engine needs and what size?
The engine mounts are already in place so I've got that covered. Thank you all for your help!
Oh...by the way. Eiji's kit includes fuel pump studs and nuts and washers,valve cover bolts,inspection cover bolts,water inlet bolts and washers,water pump bolts,fan nuts and washers,all front cover bolts and washers,oil pump bolts and washers and flat washers,oil pan bolts,distributor bolts,thermostat housing bolts and washers,thermostat cover bolts,intake and exhaust studs, washers and nuts and thick washers,timing marker and nut, all cad plated and packaged individually!
