Hey I bought this speedo cable from napa the other day and it fits in fine in the tranny but i can't for the life of me get it to fit in the back of the speedometer.
The inner cable seems to be too long. I have attached a pic.
Any help would be appreciated
Frankie
https://www.classiczcars.com/forums/topic/33013-correct-speedo-cable/
no but i have the oem housing, i wonder if that would work, if its longer i suspect it would
I will give it a try in the morning and see
Napa price 18.00 bucks, can't beat that
MSA gets expensive on this little stuff
I installed a new speedometer cable i got from Napa. I removed the cable from the houseing and cut 1/4" off the cable. Then i inserted to new cable into the old OEM housing. Works great and no bouncing. Give it a try.
awesome, i still have the old housing laying around, but if all you had to do was cut off a little, maybe ill just keep the new housing on
question, did you have any fraying of the speedo cable when you cut it?
  • 6 months later...
