Email logins are now active ×
Temp and Oil Gauge Problem
jtmader
I am experiencing weird gauge readings on my 1973 240Z. This problem is with the temp and oil pressure gauges only. They appeared to be working OK a week ago but now they sometimes don't move at all.....other times they will fluctuate up and down ever so slightly and then stop all together. It's like they are trying to move. I have replaced the oil sending unit and that seemed to work for awhile but now nothing. The temp gauge barely moves at all. I have tested temp and oil pressure and the reading are normal. Any idea's?
JEFF MADER
1973 240Z
6,000 ORIGINAL MILES:disappoin
on my 71 ,I had the same issue until I figured out that the plastic lens had some how come a bit loose and was binding against the moving part of the gauge at the lower part of the assembly .I used a small bit of mastic putty on the lens cover and was able to slightly pull out the lens so it was not binding any more , problem solved .
Have fun with your Z
Chris
  • Who's Online   1 Member, 0 Anonymous, 343 Guests (See full list)
