coop Posted September 9, 2009 Share #1 Posted September 9, 2009 Has any one had any luck using Locktite to secure the diff. ring gear bolts? Bending the tabs over fatigues them and I'd like to come up with a method that allows me to change my Quaife in and out as necessary. Link to comment Share on other sites More sharing options...
jmortensen Posted September 9, 2009 Share #2 Posted September 9, 2009 I always use red loctite. You could also safety wire them. I haven't done that but have seen it done. Link to comment Share on other sites More sharing options...
Walter Moore Posted September 10, 2009 Share #3 Posted September 10, 2009 With red loctite don't you have to heat the part to get the bolts loose later?He seems to be saying that he wants to change the ring occasionally. Just asking, not criticizing. Link to comment Share on other sites More sharing options...
Phred Posted September 10, 2009 Share #4 Posted September 10, 2009 I have used red, without bending the tabs. They came off without heating using a half inch impact gun. Phred Link to comment Share on other sites More sharing options...
jmortensen Posted September 10, 2009 Share #5 Posted September 10, 2009 I have used red, without bending the tabs. They came off without heating using a half inch impact gun. Agreed. Green is pretty hardcore, but red you can take back off without heat. Link to comment Share on other sites More sharing options...
John Coffey Posted September 10, 2009 Share #6 Posted September 10, 2009 Wedge lock washers in stainless: http://www.mcmaster.com/#lock-washers/=3kks1i Link to comment Share on other sites More sharing options...
ezzzzzzz Posted September 10, 2009 Share #7 Posted September 10, 2009 I love lock wire. If it's good enough for aircraft and military weapons it's good enough for me too. Link to comment Share on other sites More sharing options...
