Wick Humbles How to Restore your Datsun Z-car best $16.47 you could spend to restore your Z-add a Factory Service Manual, a club cd, and you have it!
generic restoration guides:
http://www.amazon.com/gp/search/ref=sr_nr_i_0?rh=i%3Astripbooks%2Ck%3Aautomotive+restoration&keywords=automotive+restoration&ie=UTF8&qid=1252586546
I bought How To Restore Your Collector Car and like it I also bought several area specific books-How to Restore Metal Trim, Automotive Woodworking: Restoration, Repair and Replacement, and others...
One thing, Restoration means only putting something back as it was-anything else is either Modification, or RestoModing-restoring some aspects of the car and modifying others. If A book does not make that distinction, stay away from it because if the author is confused over that fundamental point, you can't rely on him to be knowledgeable elsewhere.
Will
Edited by hls30.com
Bill Reagen’s booklet is worth having, if you can find a copy:
I agree, Bills book is great-it is a collection of articles he wrote for the Texas Z Club. There are some things that need to be added since it was written, but it is still chock full of great stuff!
It took me more than six months to track one down. I have been in touch with Bill about updating and making it available again...
Will
The best tool is your digital camera. Take pix of everything before you take it apart and then when it is apart. Bits are free, store them in order on an external hard drive dated and labeled or they will mean nothing.
Bag and tag everything and do as many bags as needed. Do things like strut bolts in one bag and LCA bolts in another. NOT just front end stuff. In the time it takes to do one your brain will forget where every bolt went. The more clear you bag and tag the easier it will go together. HTH, Cheers Richard.
I would suggest tripling that cost! I bought 3435 in aug '70 for $3000, bought it a second time in 1989 for $3000 and now have 8 times that in it's restoration and more to follow as i look for the hard to find parts. Hope to hav eit finished before I sign up for Medicare!
I think the book should also fairly current, because as the availability of parts changes, you may have to begin substituting something or having a part made from scratch.
Thanks for all the great input. I should clarify that this will be a resto-mod.
I bought the car in 87'+/- for $3000.00 when I decided to start SCCA road racing. I had a 944 but could not afford to risk it on the track. It was basically pretty easy to covert it from the street to the track. I will keep some of the current mods like the lowered suspension, roll cage, etc. Even when I raced my goal was to keep the car looking as stck as possible.
Regular Joe
scan0003.pdf
Regular Joe-
If you are modifying it you may want to check out the guys at HybridZ..........they come up with some great ideas as well as extreme mod's. I just used thier idea for a rear end diff correction to finally get the CLUNK out of the diff. Hoping to install over this or next weekend.
Have fun meeting the family and use the search feature a lot, odds are, it's already been discussed
Get some pictures up so we can see your progress
