920 Gold
JohnnyO
Color code #920, Safari Gold (which we always called Butterscotch) goes at least all the way back to 1969 Z #HLS30-00013 (which is that color), and was a popular color till the end of the 1971 model year production. It didn't carry over to the '72's.
I am thinking that it shows up in the PPG computer because they probably didnt have a formula for the year it was released by Datsun. I would imagine that with the popularity of the Z came the mad rush to supply paint for them as "rookie" drivers learned how to drive them and probably all to often wrecked them. That still doesnt explain why the link at TPC Global:
http://www.tcpglobal.com/aclchip.aspx?image=1970-datsun-pg01.jpg
only shows the available year as 71.
I know it was available in for 1970 model year cars. My car is fully documented back to the purchase and the color on the warranty book is 920 Gold, as are the floor boards, rear strut towers and deck, etc. I removed the vinyl inside (another thread to be started soon ;) ) and found some very nice paint that has not seen the light of day in almost 40 years. I used my razor to pull a 1x1 chip up and off to the paint store I went. I hit the closest CarQuest that mixes paint just to see if they could analyze the sample and compare it to the computer formula. I got the feeling that they didn't even want to help me out. (they must have known that I wouldn't buy from them in the endLOL) They told me that my chip was too small. So I said to the guy, "you mean I can go to Home depot with a sample about as big as my pinky finger nail and they can acurately match it but you cant do it with a 1x1 chip?" He just smiled and said "our analyzer needs a bigger chip."
I packed up and left. My sample will accompany me to the closest commercial paint distributor this week. I talked to them on the phone and they too show Gold 920 as a 71/72 color. I corrected the salesman and asked if he could analyze it and he said he could. He was at $387 for a gallon of Deltron 2000 + reducer ($46.00/QT) + clear ($156.15).
After seeing the formula posted above I am thinking about going with Dupont. I know there are a lot of oppinions on paint but can anybody give me a reason not to use Dupont vs. PPG? I plan on using the top of the line (or close to it) in either brand, I just want the correct color.
Sorry it got so winded and thanks again to all,
John
I wouldn't assume that PPG is going to be off just because of my Dupont experience. As a7dz said, he hit it right on with one of the formulas.
If it was me, I'd shoot some samples and compare them to a known correct color. You could contact Les Canaday and see if he'd compare a sample to his Nissan supplied sample if you sent it to him.
John, the reason I was going to go with the single stage and then polish was to stay close to the original style of paint. I was advised by several painters that the single stage would achieve that better. I feared that the basecoat/clearcoat would look too "artificial" but that is not the case. I'm pleased with the results. I did polish the clearcoat.
Also, I have a formula for the rear light trim panel paint. Dupont converted it for me from a different paint line formula I found in one of the forums here. In the end, I didn't feel it was cost-effective to mix it and just bought the spray cans from Les Canaday.
Terry
BPilati: Here is the link to the ppg chips online:
http://www.tcpglobal.com/aclchip.aspx?image=1971-datsun-pg01.jpg
Terry' date=' Thanks for the help. I might have to consider Dupont instead of ppg if that is the best match. I had a sample of the PPG mixed and it too appeared too dark.
Thanks all.
John[/quote']
Thanks John. Good god that 920 gold isn't even close. It's closer to orange. LOL I'm pretty certain gold was not available in 72.
Terry, I see you painted the wheel wells too. Is that a stock thing or were they just over sprayed originally. When I stripped mine I thought there was a light overspray of topcoat followed by a black paint of some sort (not undercoating) followed by red-oxide.
I was thinking painting them black for contrast. Probably use POR products.
John
John,
I had this discussion about the undercarriage with Carl Beck within the last year when I was getting ready to paint. I'll take the liberty of quoting him since this is just informational:
Hi Terry:
Your observation is correct. The undercarriage was sprayed with a very light coat of paint the same color as the body. When new, the paint under the car almost looked like an overspray - somewhat flat or dull, not a shinny paint job like the the top of the car.
Most of the 69 and first few months of 1970 production cars had no undercoating other than in the wheel wells... we aren't certain when the factory started also coating the floorboards, but most Series I cars built after 06/71 have had it.
The factory undercoat was a very fine grain, rubberized type, sprayed on the prime coat and then painted over to match the car. Usually it extends up into the transmission tunnel - but not clear around the tranny.
All this was done, before the fuel and brake lines were installed and before the suspension was put on the car. Most of the suspension components were simi-gloss to gloss black (gloss black on the fuel tank). There is an access pannel in the right rear wheel well - three or four screws hold it in place. That one panel seemed to painted with the same paint used on the body.. it was far more shinny and better finished than the wheel well itself.
Carl
What I ended up doing was spraying the entire undercarriage with Zero Rust. I then sprayed it with tintable bedliner material tinted to 920. The color comes out slightly milky looking which I was told it would. It is not a noticeable difference with the wheels on and sitting on the ground.
Terry
Here are some pictures of the undercoating (bedliner).
Terry
Wow, that looks awesome!
I will try and post some pics of my 920 undercarriage and wheel wells this Friday. It is all original and the build is 3/70. All still in very good condition. It is as Carl described in the earlier post.
The decision to use single stage paint vs. basecoat/clearcoat may also depend on how you intend to use your car. Rock chips/dents/dings will be easier to touch up with a single stage paint. So, single stage may be better for a car that will be driven a lot.
For those wanting to stay close to the original look a single stage enamel is probably the way to go. Keep in mind that the paint formulas available for re-paint are not the same as what the factory used and that the chemical composition of paint is changing all the time (try to find laquer these days!). That may account for some of the color differences. The best bet is to find a good paint shop or good painter who can match the color based on a sample. A tool bin door, gas door or inspection lid provide a good reference if the paint is still in good shape.
John,
Terry
WOW! Thanks Terry. Exactly the info I needed. As I absolutely hate undercoating I will probably coat with POR-15 then prime and paint a light top coat as Carl describes. I would guess that the POR will take the place of the light undercoating that was in place from the factory.
I have another question for you. That is a very nice and small rotisserie you have there. Where would a guy find one like that?
  • Who's Online   1 Member, 0 Anonymous, 316 Guests (See full list)
