Posted September 14, 200915 yr comment_294725 Question, I believe I have the tools necessary to do the head gasket but I'm not sure I have the ability to do it right. I have done a few things to my car like rebuilding the front end, brakes, etc. I have never done any major engine work and don't want to mess it up so it costs me more to correct than if I had someone do it for me.If I do have it done in a shop, what should the cost be, just to replace the head gasket. If the head needs work I know that would be additional. It is as 72 with an e88 head. I have read the threads on how to go about doing it but no one really talks about the dificulty of the job. I'm concerned about broken bolts, studs and the like. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/ Share on other sites More sharing options...
September 14, 200915 yr comment_294729 Its not difficult, but it does qualify as a significant project. Major issue is getting the head off without popping out your chain tensioner, then getting the valve timing right again. Not a big deal, but you will need the Honsoweitz book the first time through. I don't know if you have to remove the manifolds and cooling stuff, but you would at least have to unhook the exhaust pipe. Personally I would take them off and replace the intake/exhaust gasket at the same time. Getting the valve timing right is important, otherwise you'll bend a valve like someone I know who did it himself the first time. Maybe someone else can address the probability of breaking studs and bolts- mine all came out OK. Make sure the head gasket is the real problem, and hope there is no other damage. good luckEric Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-294729 Share on other sites More sharing options...
September 15, 200915 yr comment_294732 It's not that difficult but you have to be careful with the tensioner as mentioned. If you're just replacing the head gasket then the timing won't change because you're not going to mess with the timing. With the tensioner properly fixed in place the chain itself won't move and when you pull the head as long as you don't turn the camshaft it will go back on exactly the same as it came off. You're right to be concerned with broken head bolts and manifold studs. Those can be a real headache. One option would be to find a fellow enthusiast in your area who's done it before and is willing to help out. The head itself can be a bit heavy for one person to remove by themselves. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-294732 Share on other sites More sharing options...
September 16, 200915 yr Author comment_294859 Well I'm going to go for it.. Hopefully things go smoothly. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-294859 Share on other sites More sharing options...
September 16, 200915 yr comment_294917 You should be more than able to do it. The haynes manual should have the dimensions needed for the chain tensioner keeper or you could check napa to see if they have one. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-294917 Share on other sites More sharing options...
September 16, 200915 yr comment_294919 I think you can do it but, then again, I think that everyone should be able to work on their car. I've always been fearless when it comes to diving into things like that even before I actually had developed the skills. I always figured that I'd get as far as I could and if I got in over my head I could always seek further help. I've been successful way more often than not. Just make sure you do as much research and gather as much info as you can before you start the job. Don't be afraid to ask questions, we're here. Edited September 16, 200915 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-294919 Share on other sites More sharing options...
October 12, 200915 yr comment_297333 Not a big deal, but you will need the Honsoweitz book the first time through.good luckEricI may be looking at head gasket replacement in the near future. Does this book contain important information not found in the FSM and the Haynes manual?Thanks, Gary S. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-297333 Share on other sites More sharing options...
October 12, 200915 yr comment_297337 I may be looking at head gasket replacement in the near future. Does this book contain important information not found in the FSM and the Haynes manual?Thanks, Gary S.Yes, but it's not needed for just replacing the head gasket. I have a copy somewhere but it's really about modifying the engine for more performance.http://www.amazon.com/Modify-Your-Nissan-Datsun-Engine/dp/1931128049/ref=sr_1_1?ie=UTF8&s=books&qid=1255380630&sr=1-1 Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-297337 Share on other sites More sharing options...
October 21, 200915 yr comment_298073 Your're right, that is book for modifying, I meant the Monroe book about rebuilding the L-series datsun engine- my bad. Link to comment https://www.classiczcars.com/forums/topic/33187-can-i-do-the-head-gasket/#findComment-298073 Share on other sites More sharing options...
