Did the auto out swap. What diff?
Bobby_Lee
Hey all. I've read some conflicting thoughts on what differential I should be using. I have a early '74 260 that had an auto. I did the conversion to a 4 speed ( I already had one from a 260Z ) The stock diff I believe 3.545 that was being used with the auto is still there. What should or would be best to be using. I'ld rather have more lower end. Thanks ahead of time
Bobby
Thanks ezzzzzz I do have some mods. Triple webers, header, Monza exhaust, lite weight flywheel, Centerforce Stage 2 clutch. Daily driver when it's sunny......... No winter use (I'm in the northeast)
Would the scenario change if I also swapped to a 5 speed?
