Posted September 18, 200915 yr comment_295101 Ok so i fixed most of my problem, heres whats left. i cant figure it out at all , but im runninf 3.75 CO's during the load, and i need to be running 1.5. Anyone got any suggestions of what it could be? Did spark plugs and wires which fixed the original problem, now its just trying to get this last bit done so i can finally pass emissions. Thanks guys Link to comment https://www.classiczcars.com/forums/topic/33239-running-rich/ Share on other sites More sharing options...
September 18, 200915 yr comment_295106 Does it have a catalytic converter? If so, what's it's condition? Link to comment https://www.classiczcars.com/forums/topic/33239-running-rich/#findComment-295106 Share on other sites More sharing options...
September 18, 200915 yr comment_295109 Ok. Fist off as suggested above take a look at your catalytic converter. You have to have one in Arizona to pass emissions. What is your reading at idle? What is your timing set to? Did you adjust the a/f ratio properly?Jan Link to comment https://www.classiczcars.com/forums/topic/33239-running-rich/#findComment-295109 Share on other sites More sharing options...
September 30, 200915 yr Author comment_296067 No i passed it without a cat , but i run at about 1k at idle, idle not too sure id have to double check on that. But i did pass emissions hahaha who needs a cat pssh Link to comment https://www.classiczcars.com/forums/topic/33239-running-rich/#findComment-296067 Share on other sites More sharing options...
