I am confused on this and need some direction. I am installing Illumina's with Eibachs. The springs do not state what size goes where and I did some seraching in the past. I came upon a post that made me assume the shorter springs went up front. I installed one of them last night.
I got on here theis a.m to search for an answer for the Illuminas adjustment and came across 2 posts talking about the longer springs up front.
Do the shorter springs go front or rear? Also, on the Illuminas, the adjusting dial just spins when I went to turn it after the install, is this normal? I was thinking I would hear a click or something on each setting.
Sorry for the stupid questions, I just want to make sure I have this right as I dont look forward to re-doing it, once is plenty.
One spring ends in "1" the other ends in "2". The letters are such that when the springs are installed you can read the letters and numbers right side up. I believe the "1" is front and the "2" is rear. Call MSA and they can tell you.
