i am getting my 240 back on the road after 8 years of linger. the previous owner ran into something, which bent the bumper, broke the fibreglass headlamp housing and it seems also crumpled the frame rail as well.
attached are the photos. i need advice on the amount of damage, what is needed to repair it, and if repair is needed at all.
i presume it will be needed as the bolt holes are out of alignment due to that.
https://www.classiczcars.com/forums/topic/33322-please-advise-on-the-damage/
It's only sheet metal. You can straighten it if you start at the point that the damage occurred last and work yor way to where it began. If your not sure take it to someone who knows how.
