Posted September 25, 200915 yr comment_295699 i am getting my 240 back on the road after 8 years of linger. the previous owner ran into something, which bent the bumper, broke the fibreglass headlamp housing and it seems also crumpled the frame rail as well. attached are the photos. i need advice on the amount of damage, what is needed to repair it, and if repair is needed at all. i presume it will be needed as the bolt holes are out of alignment due to that. Link to comment https://www.classiczcars.com/forums/topic/33322-please-advise-on-the-damage/ Share on other sites More sharing options...
September 26, 200915 yr comment_295757 It's only sheet metal. You can straighten it if you start at the point that the damage occurred last and work yor way to where it began. If your not sure take it to someone who knows how. Link to comment https://www.classiczcars.com/forums/topic/33322-please-advise-on-the-damage/#findComment-295757 Share on other sites More sharing options...
