Posted October 7, 200915 yr comment_296665 does anyone know is the steering coupler bushing can be replaced without removing the steering rack assembly, it looks like it can because its 4 bolts that go through the bushing, but i dont wanna attempt it and screw something up Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/ Share on other sites More sharing options...
October 7, 200915 yr comment_296684 I've done this and I can't tell it did anything to effect the steering or alignment. I put the harder coupler in my 77 280Z a couple of years ago. If your putting the urethane coupler in just pay attention more when turning into speed bumps, driveways and dips at slow speeds. Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-296684 Share on other sites More sharing options...
October 8, 200915 yr Author comment_296763 why what happens when turning intospped bumps and driveways? Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-296763 Share on other sites More sharing options...
October 8, 200915 yr comment_296927 I have put these in without removing the steering rack. Not difficult at all. Basically, when you turn your steering wheel with the rubber insulator in place some deflection takes place. Put in the urathane and any steering input is transmitted more quickly because there is no deflection that would have occured with the rubber. It has no effect on the alignment.What I am sure Reddie73 is refering to is that if the wheels encounter something that forces them to turn - the wheels turn the steering wheel. Some of that is mitigated by the rubber insulator. Edited October 8, 200915 yr by conedodger Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-296927 Share on other sites More sharing options...
October 13, 200915 yr comment_297446 Very good explination conedodger, what you said is what I was refering to. I like the steering feel much better with the ureathane insulator, but that is my opinion. Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-297446 Share on other sites More sharing options...
October 14, 200915 yr comment_297475 Bryand2 .. I did mine and it took about 15mins. Just be careful so as to not alter the orientation of the rack portion of the shaft to the Steering wheel portion. I used some chalk and marked both pieces along with taking several photos before I dissassembled. Loosen all the bolts first and you'll have to rotate the steering wheel to get access to the lower ones. Then take the bolts out one at a time. When you get to the last bolt try to remember how the plates were arranged, it makes it easy upon installing the new one(you also have the photos if you forget).Pre-assemble the New one with the plates and bolts loosely so you know how it should be installed and then go to it. One bolt at a time .. once you get 2 bolts in the 3rd and 4th may require rotating the steering wheel slightly.No lubrication of the Urethane coupler is needed - and tighten it up!I noticed a tighter steering response after putting the urethane coupler in as my rubber coupler was mushy. I did not notice any vibration or new noises being transfered to the steering wheel after I did this change. I'm very happy I did it.Anyway - good luck .. Edited October 14, 200915 yr by moritz55 Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-297475 Share on other sites More sharing options...
October 15, 200915 yr comment_297549 conedodger said: I have put these in without removing the steering rack. Not difficult at all. Basically, when you turn your steering wheel with the rubber insulator in place some deflection takes place. Put in the urathane and any steering input is transmitted more quickly because there is no deflection that would have occured with the rubber. It has no effect on the alignment.What I am sure Reddie73 is refering to is that if the wheels encounter something that forces them to turn - the wheels turn the steering wheel. Some of that is mitigated by the rubber insulator. Great explanation. When I was learning to drive, we have an old Willy's CJ-2A with manual steering. I learned pretty quickly to keep my thumbs out of the steering wheel I have the Energy bushing kit. This thread has been great motivation for me to get on the coupler and rack bushings. Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-297549 Share on other sites More sharing options...
October 15, 200915 yr comment_297578 Just did mine as well but the whole column was out of the car. My 240Z's shaft is able to move in and out of the shaft but the 260Z's shaft seems to be solid. I also beplaced the bolts and nylon locker nuts. And yes, more POR15 as it's below what turned out to be a leaking master cylinder, rust was abundant. The Urethane bushing allows me to feel a more responsive steering and speedbumps at an angle are a pain, if you're not holding on tight. Dave Link to comment https://www.classiczcars.com/forums/topic/33446-steering-coupler-bushing/#findComment-297578 Share on other sites More sharing options...
