Posted October 8, 200915 yr comment_296975 Hey guys, the Z had a rough day. One of my U joints on a half shaft busted and I am having the hardest time replacing it. Basically, the U joint where the driver side half shaft meets the wheel assembly wore out and the shaft separated from the U joint. Unfortunately, when the shaft separated, it banged itself loose, damaging the yoke that holds the U joint. I believe that I need to replace the whole shaft, since it's damaged, but I can't source one anywhere! Any ideas? Thanks! Link to comment https://www.classiczcars.com/forums/topic/33463-broken-half-shaft/ Share on other sites More sharing options...
October 9, 200915 yr comment_297012 Try this:http://www.zcarsource.com/Best,Bob Link to comment https://www.classiczcars.com/forums/topic/33463-broken-half-shaft/#findComment-297012 Share on other sites More sharing options...
