won't start after rebuild
saridout
  • 4 weeks later...
Hello,
I ran into something like this when i performed my rebuild. I had everything TDC and only to find out that the Distributor was 180 deg out. It is an easy mistake to make. Pull the Distributor out and then set everything back up to #1 TDC (Pull the #1 plug to make sure), now look at the little "Half-Moon" line up on the Distributor and the socket on the engine. Make sure that it is aligned properly, I am betting that this is you issue. I can send you FSM pics to get into more detail if you need.
-Andrew
