I have, and it has gotten a great deal more difficult to find-most of the readily available stuff is way too thick to be unnoticeable. I sent some to Ed a couple of years ago as a thank you for some parts help, and I have a couple of sheets put up for my cars.
I'll see if I can find some more, and post when/if I do.
Will
Keith,
I have two sheets in a manila envelope I placed there three or four years ago-no name or part number on the material, but is the same thickness as 20lb paper, after removing a plastic film(easily peeled off), but because of the magnetic pull, it conforms to the shallow relief in the areas that the stickers are placed in.
I'll go back to the local supply house I originally bought it from and see if they have more or can tell me what it was/where to get it.
Will
here are ones I found on ULINEs web site http://www.uline.com/BL_8250/?pricode=WM219
Here are some from US Markerboard - 1/32 of an inch thick. http://www.usmarkerboard.com/Magnetic-Sheeting/8108?gclid=CKmo3vDK9p0CFaM45Qodpk93pg
The thinist from Magnetking.com at 1/64 of an inch. http://www.magnetking.com/#psamagnet
I have purchased all the decals from Mike at Banzai. They have been in the engine bay for two summers and are holding up extremely well. Mike is a great guy to work with. I highly recommend him.
Dan,
I really appreciate your efforts. I am glad that you are recouping your cost for the project. My car is going to look like fantastic with the new decals, etc.
Andrew(ZCurves)
  • 14 years later...
1 hour ago, zed2 said:
Which "OK" decal is correct for a January 1970 production 240Z?
A (Zeddsaver):
B (ZZXDatsun):
Thanks,
Keith
The second one from Mike
https://www.zzxdatsun.com/catDecals.php
