October 15, 200915 yr comment_297563 I always enjoy watching the re-build process. Looks like you have some really good body guys working on her. Hope to see final photos of the car back on the road soon. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297563 Share on other sites More sharing options...
October 15, 200915 yr Author comment_297577 Great story, looking forward to seeing the finished result!You and me both. The body work would have been finished by now, except for a freak hailstorm that swamped the body shop in late July-early August. Unfortunately, I'm a one off, and since they're pretty much the best in New Mexico, they get a ton of insurance jobs, which pushes me back in line. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297577 Share on other sites More sharing options...
October 16, 200915 yr comment_297632 I am glad to see you were able to save the car. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297632 Share on other sites More sharing options...
October 16, 200915 yr Author comment_297652 It's next in line in the paint booth for primer! Getting masked off: Hood finally done: Fender finally done: Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297652 Share on other sites More sharing options...
October 16, 200915 yr comment_297654 Jehannum,It looks like they are doing great work on your car. If you aren't already planning on this, you should really consider having them remove all of the glass before they paint. Even if they go a great job masking, you will still be able to tell that the glass wasn't removed.-Mike Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297654 Share on other sites More sharing options...
October 16, 200915 yr Author comment_297655 Jehannum,It looks like they are doing great work on your car. If you aren't already planning on this, you should really consider having them remove all of the glass before they paint. Even if they go a great job masking, you will still be able to tell that the glass wasn't removed.-MikeThey're going to. This is just the first coat of primer, which they told me is just a guide coat for the body guy to go over what he's done and correct any bad spots.I'm unsure whether they plan to take the rear window and windshield all the way out, though. As you can see, they've already taken the finishers off around the F/R glass, which would cover the paint edge (plus, I was quite insistent that they not break the vertical defroster rear glass). Edited October 16, 200915 yr by Jehannum Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297655 Share on other sites More sharing options...
October 16, 200915 yr comment_297658 I'm unsure whether they plan to take the rear window and windshield all the way out, though. As you can see, they've already taken the finishers off around the F/R glass, which would cover the paint edge (plus, I was quite insistent that they not break the vertical defroster rear glass).Well, like I said, if it were my car I would make sure all the glass is removed for a full repaint where you have already had so much work done to the car. The stainless trim pieces just sit in a channel in the middle of the seal, they won't cover the paint edge. I would also worry about the channel being torn with the trim being removed and reinstalled. If you are worried about their ability to remove and replace the glass I would pay a specialty glass place to do it. But it is your car, so what ever you think is best.-Mike Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297658 Share on other sites More sharing options...
October 16, 200915 yr Author comment_297662 Well, like I said, if it were my car I would make sure all the glass is removed for a full repaint where you have already had so much work done to the car. The stainless trim pieces just sit in a channel in the middle of the seal, they won't cover the paint edge. I would also worry about the channel being torn with the trim being removed and reinstalled. If you are worried about their ability to remove and replace the glass I would pay a specialty glass place to do it. But it is your car, so what ever you think is best.-MikeYou've given me something to think on, that's for sure.I'll go down this afternoon and have a talk with Chris about it.Body shop is Loid's Rides, by the way. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297662 Share on other sites More sharing options...
October 17, 200915 yr comment_297698 Great pictures of the before and the during. Look forward to seeing the final results. Thanks for including the name of the shop as I will be looking for a place to work on 30855 in just a few months. I may have to drop by early next week and maybe see the end results, if your car is still there.-Bill- Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-297698 Share on other sites More sharing options...
October 22, 200915 yr Author comment_298187 You've given me something to think on, that's for sure.I'll go down this afternoon and have a talk with Chris about it.Body shop is Loid's Rides, by the way.I went down today and removed the side windows.The front and rear glass will be fine - the trim is off, the adhesive is scraped out, and it's primed down to the channel around the glass.I was kind of bummed that they weren't going to remove the side glass, though. After talking with their body guy, the worry was that my interior would crumble during removal. I got it out no problem along with the glass in under an hour without breaking it, though (which means that they could have done so easily). Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-298187 Share on other sites More sharing options...
October 22, 200915 yr Author comment_298188 Great pictures of the before and the during. Look forward to seeing the final results. Thanks for including the name of the shop as I will be looking for a place to work on 30855 in just a few months. I may have to drop by early next week and maybe see the end results, if your car is still there.-Bill-I can't recommend the quality of their work enough - they're really top notch, but expensive.My '71 is 31917, so we're all of 200 cars away - maybe on the same boat, even. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-298188 Share on other sites More sharing options...
October 23, 200915 yr comment_298297 Went by "Loid's Rides" this afternoon and looked her over and asked general questions about their work and what not. I have to say what they have done so far looks REALLY good . Appear they pay a lot of attention to detail. I looked at a '55 Chevy they did and it looks great! They are on top of my list when it comes to taking mine in for the "makeover". Keep up on the pictures. Link to comment https://www.classiczcars.com/forums/topic/33519-resurrection/?&page=2#findComment-298297 Share on other sites More sharing options...
