Recently Browsing 0
So it's been shown before by me and some others but there's not a specific thread on the subject, so here it is.
Go down to your local Auto Zone and pick up a 9-300 Universal Washer Fluid Pump for about $11.00.
When you unpack it, you'll see that it has a plastic foot attached to the back end of the pump motor. You'll want to cut it off. Use a dremel with a cutting disk or a simple hack saw. Try to keep the cut close to the body of the motor, so it'll be able to slide thru the rubber boot of the washer fluid bottle.
Remove your old motor by disconnecting it and sliding it out of it's rubber boot. Now take a small drum sander on your dremmel and Hone out the inside of the rubber boot, making sure to remove the motor retaining lips from both sides of the lip. Hone it out till the new motor will fit in there snug.
Insert the wires into the rubber tube from the front and pull them through and then force the motor in till the rubber boot just touches the plastic pump part of the pump.
Connect the tube of the resevoir to the tip of the pump (pointing outwards)
Connect the tube that goes to the washer nozzles to the other tip that is now pointing down.
Connect the white pump wire to the Black/yellow wire from the harness
Connect the Black pump wire to the black wire from the harness
Make sure to cut off the excess wire so it don't look ugly.
Slide the resevoir back into its holder and you're done.
https://www.classiczcars.com/forums/topic/33533-replacement-washer-fluid-pump-how-to/Share on other sites
