Email logins are now active ×
found oil underneath carb
clindayag1
Typically, it's not oil. It's gas seepage with dust and dirt to darken it and make it look and feel like oil. Also, the front carb is near the block breather tube, which can leak and be caught on the front carb area.
When you choke it too much, the overflow will travel down the fuel valve and collect on the adjuster nut and tube. Don't worry about it.
Dave
  • Who's Online   1 Member, 0 Anonymous, 479 Guests (See full list)
