Posted October 22, 200915 yr comment_298146 Ok I searched here first to see if some had posted these already but found nothing. I'm looking for the factory motor specs, you know displacement, bore, stroke, cam lift things like that. I have a built L24 motor and was trying to figure out the differences in motor specs. Thanks a lot. Link to comment https://www.classiczcars.com/forums/topic/33611-factory-motor-specs/ Share on other sites More sharing options...
October 22, 200915 yr comment_298147 Here's a link to the L20A, L24 Service manual:http://www.xenons30.com/files/FSM%20L20aL24engine.pdf Link to comment https://www.classiczcars.com/forums/topic/33611-factory-motor-specs/#findComment-298147 Share on other sites More sharing options...
October 22, 200915 yr comment_298150 Lots of info here....http://www2.zhome.com:81/ Link to comment https://www.classiczcars.com/forums/topic/33611-factory-motor-specs/#findComment-298150 Share on other sites More sharing options...
October 23, 200915 yr Author comment_298275 Thanks a lot I'll check them out. Link to comment https://www.classiczcars.com/forums/topic/33611-factory-motor-specs/#findComment-298275 Share on other sites More sharing options...
