Skip to content
radiator question
Hello guys
About a week ago my radiator developed a leak. So I ended up calling up a radiator shop and ordering a radiator. They told me it was an exact replica of what I had. It came in today and I find two things different.
1. The radiator has the drain plug in the center not on the driver's side like advertised.
2. It has two outlets for the automatic transmission that came with other Z. (mine is a manual).
To my amazement the radiator I bought is roughly ten pounds lighter than the one I have. It is the same size and everything. I'm wondering a number of things. Is it possible to just plug the transmission lines and stick the car in there or should I take it to a radiator shop and have it trimmed off? Secondly will the drain plug in the center affect the skid plate. What I mean is can I put the radiator in and then the skid plate with no problem?
Thanks for the help
Jan
Don't know about the drain plug but as far as the trans cooler lines you don't have to do anything to them as nothing will be running through them.
Really? I would think fluid would come out of there if I drive with a manual and there's nothing hooked up. Can you explain why?
What fluid? It's just a copper coil that hooks to the auto trans lines and cools the trans fluid by circulating the fluid through the coil. There's no coolant in that part of the radiator.
Oh that makes perfect sense now. I thought that the transmission had an internal cooler and that the coolant would flow through the radiator to the cooler and than back to the radiator. (works this way in my old jeep). So as far as I am concerned the two little connections on the bottom of the radiator don't do anything at all for me?
Jan
Nothing at all. That part of the radiator is complete seperate from where the coolant is. I had an auto trans radiator in my 78 which had a 5 speed. I'm pretty sure that's the only kind of radiator you can get for them anymore.
Over in the UK we have our radiators reconditioned (a new core in the old top & bottom) it's a lot cheaper.
Yes, that is my preference as well. I have a very good rebuild shop who has been doing my work since the '70s. I am more comfortable with their rebuilds than I am with OEM or other source replacements. He also stands firmly behind his work.
  • 3 weeks later...
Best thing I did to solve all cooling problems was have my rad re-cored with three rows instead of the stock two.
Thanks guys for all your help. I did get a new radiator OE replacement and removed the condenser from in front of it. The car runs nice and cool.
Jan
....removed the condenser from in front of it...
In my experience (as an HVAC/MVAC tech) the condenser doesn't affect engine cooling but if you don't have AC, you don't need it.
Edited by sblake01
