mbarjbar Posted October 26, 2009 Share #1 Posted October 26, 2009 How can I tell if my car has factory A/C or some aftermarket system? Car is a 1970 Z. Looks like a York compressor, positioned lower left under the distributor. There is a small dial for the A/C attached to the bottom of the dash to the right of the steering column. Does not work at present.Thanks, Mike Link to comment Share on other sites More sharing options...
zed2 Posted October 26, 2009 Share #2 Posted October 26, 2009 Mike,The A/C on the 1970 240Z was not a factory option in US destination cars. The unit you are describing is the aftermarket system, usually installed by the dealer.I have a similar system. Is there a manufacture's name or part number on the drive belt to the compressor?Thanks,Keith Link to comment Share on other sites More sharing options...
mbarjbar Posted October 27, 2009 Author Share #3 Posted October 27, 2009 Keith,There is a plate on the compressor, under a lot of crud, that I will clean to read. Looks like a set of numbers. I'll let you know what the numbers are tomorrow. Nothing on the compressor drive.Mike Link to comment Share on other sites More sharing options...
zed2 Posted October 27, 2009 Share #4 Posted October 27, 2009 Mike,I would also like to know if there is a manufacture's name or part number on the drive belt to the compressor?Thanks,Keith Link to comment Share on other sites More sharing options...
madkaw Posted October 27, 2009 Share #5 Posted October 27, 2009 Here are the original brochures for the AC Link to comment Share on other sites More sharing options...
