Posted October 25, 200222 yr comment_17554 I need some engine compartment parts for a restoration, so they should be in top condition. Here is a detailed description of what I need: 3 rubber clamps that wrap around clusters of brake piping on the firewall - one has 4 holes in it, is slightly curved, and mounts on the back-center of the engine compartment, just above the transmission. It holds 3 brake pipes and a fuel line I think. The second rubber clamp has 3 holes for brake piping and mounts just to the left (toward the battery) of the first clamp. I'm not sure about the location of the third clamp (my mechanic disassembled them), but I believe it also has 4 holes. Again, they all hold piping and are themselves held in place by flat steel clamps and bolts. See picture of old ones attached. Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/ Share on other sites More sharing options...
October 25, 200222 yr comment_17562 It's not exactly clear as to what you want here. Is it confimation as to what these clamps are for? it may need some clarification to get a response... just my 2cents. Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-17562 Share on other sites More sharing options...
October 26, 200222 yr comment_17614 I think it's exactly clear what you want but i'm sorry i don't know where to get some. If you do find out ---- post where you found them ---- please?! Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-17614 Share on other sites More sharing options...
October 27, 200222 yr comment_17628 You might try MSA or possibly ZCarsof Arizona. It might be possible to find them at a dealer that has some good connections with Nissan. I don't remember ever seeing them listed in any parts catalogs, but you might get lucky and find someone who has a source that may have recently surfaced. Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-17628 Share on other sites More sharing options...
October 27, 200222 yr comment_17630 Originally posted by jzorzy I need some engine compartment parts for a restoration, so they should be in top condition. Here is a detailed description of what I need: You can't buy those rubber clamps anymore. Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-17630 Share on other sites More sharing options...
November 6, 200222 yr comment_18387 jzorzy- At the local Hardware store I bought some rubber of the same size -- drilled it out to fit -- then cut the access slot down the middle. It worked very nice. The curved piece formedit's self when installed. It worked best to cut the access slotwith a rasorblade (I tried with a hacksaw 1st, kinda tore it upon the edges-- looked bad) the rasorblade makes the cut smooth. - Jeff Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-18387 Share on other sites More sharing options...
November 13, 200222 yr comment_18931 The rubber clamps in my parts car were in good shape. Maybe you could get lucky at a junkyard or better yet...get a parts a car!Hope your enjoying the process!Jim Link to comment https://www.classiczcars.com/forums/topic/3367-rubber-firewall-clampsgrommets/#findComment-18931 Share on other sites More sharing options...
